Hoover Twin tub
If only ...
... I were living closer to that beauty ...
... I could have grabbed it !
Model 0513 - what a particular mix of the white and coppertone !
Interesting also to note the date scribbled on the users guide ...
And, the unusual bottom of that spin basket with a new design
making it look more alike the spinners in their 0519 models !!
Cool subtleties in the development of those -then new- models.
If you look under British Twin Tubs
You will see our version which has a heater in it. There is also a non heated version with the same wash tub as the USA Model...
Ho! Yes, Austin,
think, at least here in Canada, never seen one with the heater
and, most probably, none of the US models as well.
@unclejohn
I assume its down to the power supply us being 220/240 to all outlets means you can plug anything in where ever you wish. Mind you a 3kw heater in a wash tub of cold water can still take over an hour to heat up, I know we did some boiling in the wash tub but it was mostly used to boost the heat when going cool.
