the belts just had its day? frayed & broke or.....
hi tom!
i'm not an expert or very mechanical but, i recently bought a Hoover 0510 (american-made) and i've been getting pretty familiar with how my Hoover works (kinda). i still have A LOT to learn, i know. but one thing i can tell you that happened to me was that when i got my Hoover home, everything seemed to be working n it. but of course, the drain pump leaked water.
after tinkering around and changing parts & taking off the drain pump, cleaning it, putting it back together & back on. the drain pump was leaking soooo much more water!!! so, i rolled the Hoover outside and filled the washtub with water and took the back off the cabinet to see where the water was coming from. well low & behold, the water was just dripping at the drain pump. but after really close inspection, i realized that the water was coming from the washtub drain hose that connects to the drain pump. if i squeezed the washtub hose, the water would squirt out more. i had the hose clamp on properly so, i couldn't understan why it was leaking, there were no cracks or slits in the hose??? i just figured that the washtub hose is hold & worn out. i put a new washtub hose on my Hoover and now, there is only water dripping out the bottom of the drain pump. but waaaay less water is on the floor after changing the washtub's hose. so, i think these parts (hoses & belts) just "wear out" after time & use. so, one must replace them with new ones after years of use. that's what i seem to be finding out, while i'm tinkering around with my lil' Hoover.
sorry for the long message but sometimes i can't help it.
i hope reading my message will help you & others on here. i know that's how i've learned alot, was by reading other's messages on here.
SO THANKFUL FOR THIS GROUP. THE NICEST GROUP OF PEOPLE I'VE MET!!!
lovingly,
christina ;o)
peace......
