Hotpoint 18680 restoration
sesteve
Jun 22, 2012
795
London, UK
As promised, here is the thread of the restoration of this machine last summer. It will help me with the 1828 and hopefully will be useful to others.
Original photo from eBay back in early 2014 – machine was in Sussex and bought for 99p. The paint had worn off the top round the soap dispenser and the kick strip was pretty rusty but other than that it was not too bad although the house was being renovated so it was covered in dust
Serial number dates this as March 1983. There was a long wait as it was in the storage unit awaiting the move to the new house which seemed to take forever but finally was placed in the new test facility waiting its first run (with a non-matching dryer on top)
So the restoration strip down starts. The removal of the control panel showed lots of old powder and grease - bleugh. You can see the motor lurking behind the timer and all its wiring
Original door boot – note the hotpoint logo on the 12 o’clock position but the door boot had seen better days and did have a hole in it which was the main cause of the wet floor
Front panel off with the pressure switch and door interlock hanging. Close up of the heater and pressure vessel. Always a good idea to photograph the connections first!
Behind the back panel was a bit more promising as it appeared clean and stain free – oh wait look at the rust down by the pump! I’d already taken the belt off. A close up of the door interlock pecker and the bolt number for the back plate – no.12 the last one to be undone to reveal …..
This eek! A fair bit of corrosion. There was no sign of the heater bollard as detailed in the service manual either!
This lump is actually a loose bit of metal. The strip of metal in the middle must be to help divert the water down to the sump during spins unless anyone knows differently?
The corrosion didn’t stop in the lower parts of the tub either – not a great photo but it was also corroded at the top on the front seam. Looking sorry for itself in the second picture!
Time for more strip down. Cabinet off giving great access – this chassis arrangement is similar to the Servis Quartz although the Quartz did not have a wraparound cabinet.
The motor and concrete weight removed and the tub off the suspension. You can see a bit of external corrosion especially on the side of the dispenser inlet and along the front seam although that was pretty superficial. The rear gasket recess at the top didn’t look too great either!
Some internal pitting and the full view of the horror at the bottom – no evidence of a hole for the heater bollard either
Pulley removed to show the outer bearing and the drum removed showing dried grease and rusty bearings. The backplate wasn't too bad – just a bit of corrosion around the lip.
Although the water seal was very hard and had failed The inner bearings seem to have faired ok though
The rest of the stripdown continued. The module appears to be original although the pump may be a replacement – difficult to tell.
The state of the chassis can now be seen on the dispenser side.
Out with the chemical metal – the first time I had used this stuff so not as neat as it could have been! I treated all of the poor areas. After a quick sand down I coated the whole of the outer tub with the two pack paint product recommended by another member – it has worked a treat although the cats started acting strangely with all the fumes!
I managed to track down a heater bollard – unfortunately it didn’t come with the rest of the fittings so I had to bodge some up. I covered it with debor glue to be on the safe side. The last pic shows the new hole drilled for the bollard
The dispenser side suspension rod was beyond repair but I had a spare off the 9544 to use. Unfortunately the thread at the top was not quite as long as it needed to be so I had to build it up with a couple of extra washers. The rubber mounts were in good condition so I reused them but replaced the plastic pivots as they were quite worn.
reassembly Alfresco style!
The weather was nice so I decided to commandeer the garden table for reassembly! Concrete weight and sump hose refitted and you can see the heater bollard nut too. Heater re-installed and the dispenser hose glued securely in. A new hose was ridiculously expensive and the hose itself is in pretty good condition so hopefully it will last
I have a Hotpoint bearing tool set - £6 off eBay so gave it a go and it was quite easy to take them out.
Bearing-less backplate after the pressure wash. There seemed to be a bit of pitting in one of the recesses on the inside of the plate so I bunged a bit of chemical metal in just to be on the safe side.
Close up of the old bearings all manked up. New sealed rear bearing and inner bearing and seal re-fitted using the same tool!
Gave the spider the pressure wash treatment and it revealed that it was not as good as it first appeared!
Luckily I had a spare complete with the sealed bearings
Time to tackle the chassis – this seemed like a good colour match. After a good sand down and a coat of red oxide paint it was sprayed and left to dry. One can was not quite enough but the insides can’t be seen easily
Frying tonight! The fish slice was used to remove the console cover. Washing powder had damaged the very thin aluminium around the dispenser so out with the chemical metal again!
Time for re-assembly. Wheels back on and suspension mounts re-fitted. The mounts were in quite good condition but I swapped them over
