How do people.
Hi Alex.
I held off posting piccies of the 6200, as the ones I have are from your brochure, so the honor should be yours.
One way round not being able to post .pdf files to the forum is to take screen grabs instead (you may know this already - its a bit of a faff!):
Open Microsoft Paint.
Then open your .pdf and scroll to what you want to post.
When you are happy with the way it looks on screen, press the 'Print Screen' key (can be found to the left of scroll lock and to the right of the F12 key).
Then go back to Microsoft Paint, which should have opened a blank white background.
Right click and select 'paste'.
Whatever you screen grabbed will now drop onto the blank page, which can then be saved as a .jpg or .bmp and posted on the forum.
Good luck.
Definately was an slightly unusual looking machine, what with the tri-spoked dials.
As far as I know, this machine was manufactured by Creda. Below is the Creda 47307 and its likeness to the 6200 is very apparrent. This style of machine also formed the basis of the 6200's replacement, in the form of the 6240.
Paul
