hotpoint 9530w electronic 1000 plus
Hi Matthew
I assume you mean the drum pulley and nut. I've found the only way is with
a socket drive and a long lever as you'd use to change a wheel on a car, wrenches and adjustable spanners are more likely to result in accidents than success in my opinion, I'm sure it's a
m20 thread with requiring a 30mm socket, but worth checking that. As always, worth looking up older threads in the searchalator, the thread entitled `Introducing the Hotpoint9562 electronic de luxe l.e.' shows me using the socket in one of the photos. Even with the long lever and the pulley held with a chock of wood, the force required and almost roll the machine over, thats how tight some of these nut can be.
Hope all that helps.
Mathew
hotpoint 9530w
i have tried this but with a ratchet and a long extension but it still isn't moving
i have bought a 30mm spanner and that has done the same thing
i think the spanner + the neighbour's lump hammer is an order or even his sledge hammer on the spanner, i hope it doesn't snap or the chock slip as a spoke is already snapped off
i might actually just cut it off with my hacksaw if the hammers and spanner fail.
Fair enough
they can be tough especially if it's been on there many years. all the best with it, this is the model my grandparents got in 1986, £309 from south wales electricity board shop.
mathew
If the bearings are good, why do you want to undo it? Best left alone if possible.
Be careful. I was struggling to undo the same nut on a 9560W over 20 years ago. Slipped and severed a tendon on my hand. Needed a stay overnight in hospital and surgery next day. I still have the scar.
I did get it undone when I got back and recovered ... wearing strong leather gloves. One lever through spokes of pulley, into ridges on back of drum, to stop pulley turning. Lever on socket on nut, belt lever with mash hammer till it releases. Wear eye protection, ear muffs and heavy leather gloves. Use strong tools that won't snap with this abuse. Yours has stayed together 20 years longer than mine, so will be even harder to undo...
Restoring an old washing machine is a wonderful thing to do, but it is not worth injuring yourself.
Hi Matthew.
The photo is from way back when a 95620 was repaired, by Mathew, Rob and myself - photo is the one from the 95620 thread that I created at the time.
Exactly as Gizmo and Mathew describe.
As has been said before, Hotpoint 95's are full of sharp edges - if the bearings are still good, then I would leave them alone until they start failing.
Either way, congrats on acquiring a very good machine (my aunt's lasted from 1986 through till around 2012/2013 and was written by an upstairs flood, which came through the kitchen ceiling).
Paul
ah now you can see
i'm using the socket with a short extension shaft so that the long lever, probably about a meter long, is clear of the back of the machine, so that if anything slips we're away from sharp edges etc, but I too have been to A and E, but that was trying to get the clamp band around the front of a servis door boot, the thing sprang off and cut my eyebrow area. All we can say is to learn these lessons along the way.
Unscrewing the pulley nut of vintage hotpoints
I'm also having the same trouble undoing the pulley nut on my hotpoint aquarius wd62 washer dryer which is the same internal design as the 95s.
I've used the stick a hammer/rubber mallet to lock the drum and a 30mm ratchet socket to help remove the nut it did nothing.
I even wacked the 30mm ratchet spanner really hard with a hammer it did nothing.
Thought I would post as I appear to be in the same situation too as OP
Janak
well i finally acted on the bolt
i have taken the 9530 apart and taken the entire drum unit out of the machine along with all of the concrete weights and the smooth GEC motor. the bearings are fine as well and the inner drum i think is undamaged i will have to see. the reason that i tried the bolt in the first place was due to the inner drum rubbing the front plate at 1000 rpm. i hope that i can get it off with a 30mm spanner and the neighbours lump hammer or through just sheer force and a lot of patience.
i have never had a bolt this arrogant to unscrew as usually the bolt just unscrews and the pulley also unscrews and the drum usually comes out with relative ease and the repair can be made
but this was my fault but i have never had a pulley break like that ever.
