kevhallett
- Joined
- May 11, 2013
- Messages
- 7
Hi, Not long owned an old Hotpoint Empress washer, the Old type with Octagonal Drum, with a heater.
Last Week, was half way through a wash, when it sounded like changing gear on a car without using the clutch, then it seized and there was a horible Motor smell and the Motor wouldn't turn, after wriggling the agaitator back and fourth by Hand, the machine now does one sweep, then makes the grinding noise and it stops. Also the drive shaft for the wringer has stopped turning.
Parts seem to be very hard to get for the machine, but my main question is: How do you remove the Agitator shaft to remove the Gearbox? There seems to be very little room to work on the Machine from Underneath. I need to get the gearbox off to assess the Damage, and then I'll know what I need to try and get (or get made)
Thanks in Advance
Kevin
Thanks in Advance
Kevin
