Some bits of advice adding new bearings to a 95 series...
From the 95620 and 9560 Masterclasses which took place in Cardiff...
a) on taking to pieces, beware of brittle facia - any rough handling will produce a crack!
b) on taking to pieces, beware all removable metal parts on the backs of hotpoints - they are like razor blades and will slice nice and deep into any flesh applied to them without care and attention.
3) you will need someone to trap the drum pulley and hold it still, whilst you unlock the drum from it.
iv) put new bearings into freezer to get them nice and cold. Shrinks them slightly.
5) apply gentle, NON-OUTER TUB MELTING, heat to the hole the bearing go into. this could make it microscopically a bit bigger and easier to get the chilled and slightly shrunken new bearings into.
hmmmmmmm......anything else? mmmmmmm. Mathew? Rob? Anyone?
