norgechef
Hi guys. I recently posted about my latest acquisition, a 1979 Canadian Camco manufactured HotPoint RimFlo. Same as the US models as far as I know aside from the bleach dispenser and white porcelain tub. It’s been running great so far. Sometimes has a squeaky belt slipping noise during agitation (only once in a while) which may require a new belt, but the tension seems fine for now.
My question is, why does the control panel point to the machine having the HotPoint “handwash” agitator, but it does not appear to have one. Is it possible there’s one under there even with the traditional appearance of the ramp agitator? I’ll post some pictures of what I mean. As you can tell the agitator appears to be a basic one-piece GE-style ramp activator, but the control panel has a logo near the timer with two agitators. One small and one large, with a star under the small one. You’ll notice it seems the star co-ordinates with a setting on the timer (between the 6 and 3 minute position) and also with the delicate speed setting and the lowest (below minimum) water level position. As if to say these are the settings to be used with the handwash agitator. But there is none, or so it appears.
It’s possible it could have had some work done at one point and had the original mechanism changed out for a new agitator if the transmission or splines had been replaced, but I don’t see anyone wanting to spend extra money on a lower-end agitator to go with any other new part. Unless the actual agitator itself was damaged in some way and needed to be replaced. Any info or advice on why it would have these “star” settings and the handwash agitator logo with seemingly no use for them would be great.
Also, aside from that, I’m perplexed as to how the brake works on these machines. Could someone explain this as well?
Any info would be appreciated, thanks! Pictures are below. Sorry the machine is missing the speed selector knob, it was like that when I bought it. Slow does work, but I only need to use normal speed anyway. Can turn it to slow with my pliers if I need to.
