Hotpoint SPOT * LESS continued
I have been intending to submit a "frontal's cavalcade of
early diswashers" thread and request that you do a reworked
version of Imperial Thrd #1064 - 1/23/2005 , Pst# 54464,
'Great Topic!', but I am over budget and behind schedule!
Georgious Dishwasher
I would love to see the interior. They sure made nice dishwashers years ago. I hope this becomes your daily machine. Mike
Wonderful dishwasher. I had a friend who put one just like this in her new house built in 1956. It was a fine machine. It used a fan in the bottom of the tub to sling the water up on the dishes.
Jerry Gay
A Great Hotpoint!
Boy does that machine bring back memories. We had that same machine but in white when I was a little kid in our first home back in the late 50's(dating myself). I remember mom letting me push the start button when she was going to turn it on. WOW! A great machine too, if a bit noisy. I remember the top rack adjusted to a different size too. It's funny I was going through some things and came across original instruction booklet for that machine, It was neat reading about it again! Hope it works well for you Enjoy it as it is a keeper!!
Cycla-Fabric
Hotpoint Happenings
Hey Guys,
Sorry I didn't get back sooner with an answer, was away this weekend. I don't have a scanner currently hooked up to my computer but I will see what I can do. I know I can scan the manual at work into a pdf file. I will give it a shot and see what comes up. And if that doesn't work I will try to take digial picture of it. Keep the fingers crossed and wish me luck.
We have a portable version of this machine in white. When I found it, the cycle dial was broken, but I went to an old parts dealer and bought the last one. There is a C-7 bulb behind an opening in the metal behind the dial that lights up the portion of the cycle that is being performed. There is a one minute overhead spray to warm up the machine (it fills through the brass pipe that connects to the brass fitting on the top of the tank). Then with the motor on, it begins filling for the first wash. It meters the correct amount of water through a metering coil in the motor. When sufficient water has entered, the load on the motor shuts the fill valve. The detergent is washed out of a small recess in the door with a little perforated strip across the lower part so that the detergent does not fall onto the bottom of the tank when the door is closed and get washed away during the 1 minute spray. During this wash, water fills both cups that form the cover of the detergent dispenser. At the end of 5 minutes, the dishwasher drains. Also draining at this time is one side of the two pocket cover for the non-electric detergent dispenser, leaving the pocket that covers the detergent cup for the second wash empty while the pocket next to it on the other side of the pivot point stays full. When the second 5 minute wash begins, the empty side is tossed up, uncovering the fresh detergent. This wash is followed by two one minute rinses and then the fan circulated hot air drying.
The top rack is pretty neat. On the rack is a small stainless steel badge that says turn for tall glasses. So, if you extend the rack all the way and lift the vinyl rack out of the frame it rides in and turn it around, it sits in the frame slightly lower. Then the badge on the front of the rack says turn for taller plates and when you do the notches in the rack line up differently so that the rack is higher in the frame. I was at the beautiful home of some friends' grandparents one Thanksgiving and having fun with their Hotpoint that was similar to this. They said something about the glasses that would not fit when I showed them what the rack would do. They had used the dishwasher for 15 years and had never noticed those instructions.
I think we also still have the built-in model that was put out at the curb in front of a mid 50s house on busy Reno Rd. NW in the District. I had a friend go over there with me in my Celica hatchback. We stopped, released the hatch, grabbed the Hotpoint and pushed it inside, latched the hatch and were driving away in less than a minute.
