ronhic
Launderess....
Maybe from a North American perspective, but certainly not for most people here. If you asked an Australian who wanted an automatic if they had to choose either a wringer/twin-tub or a semi-automatic, they would choose a semi-automatic and they would expect a machine that looked like an automatic, but where they controlled the steps...AND they didn't get their hands wet or have to touch the laundry until it was finished.
Most people in North America went from either a wringer or twin-tub to an automatic. That didn't always happen here as we had semi-automatics that filled a much needed niche in our market.
Just as wringers and twin-tubs were a huge step up from doing the whole process manually, in Australia, a semi automatic was one step again between a manual machine and a full automatic. This was brought about primarily because of the very high cost of appliances here. Much of that cost was the 'automatic' part - timers. So the manufacturers here brought out true semi-automtics where you didn't touch the actual washing until it is finished, but still needed to turn a switch to change from one process to another.
Wringers and twin-tubs do not work like this. You cannot complete the whole cycle without actually moving the washing at least twice. That is, from the wash to the wringer/spinner, back into the wash tub to rinse (some twin-tub spinners and Nth AMerican dual tub machines excepted...you only have to touch it once there)and then back through a wringer or the spinner after it was rinsed. Regardless, my point is you had to actually move the washing out of the tub at some point in the process.
Most Australians would consider this to be a manual process/step and, as a result, a manual washing machine.
A true semi-automatic removed this step and meant that you could wash, rinse and spin without touching the wet washing but still had to control the steps.
