I see from the posts I've found that I'm lucky to have a KDS-18. This strengthens my resolve to fix instead of buy, but I can't seem to make any progress so far. I think I need to remove the lower spray arm and some other things to clean everything out, as there's little water coming out of the lower spray arm and none from the upper arms, and nothing spins. However, the lower spray arm does NOT simply lift off, nor does it appear to have a screw... Thank you for your help!
