Ditto: Not quite sure what the problem is
If it is the angle of the spigots at rest it looks like you will have to cut a notch in the dry wall/plaster to accomodate the connections.
If you only intend to hook up one machine for now you might want to get some covers to screw on the exposed spouts.
Also, those splitters look like there intended for COLD water use only.The splitters I got are brass w/out valves so if i only have one machine hooked up I cover the open ends with the matching brass covers from Home Depot, BTW.
Those splitters with valves are generally plastic and not suitable for hot water use over time.
-Russell
