How long does my washer realistically have left?
ryner1988
Mar 3, 2015
700
Indianapolis
Well, I figured issues would start to crop up eventually, just could not have imagined it would be this soon...
My helical drive Maytag washer has trouble starting the agitation cycle, and also makes a strange noise on the drain cycle, kind of a grinding/scraping, like something is loose or rubbing in there. It's really hard to explain so I'll try to get some audio up next time I'm using it. The same sound can be heard when the motor starts after fill, when the machine starts agitating. It does eventually start to agitate, I'd say after about 10 seconds or so it gets fully going, and the noise also is basically a non-issue after that until the drain cycle. Then the weird sound comes back again once the motor starts up to drain the machine, but goes away once the washer ramps up to full spin. So basically, it sounds like the weird noise only happens when the washer is stationary, i.e., not agitating or spinning.
Coupled together, I imagine this machine doesn't have long, which is what I figured when it was brought to me a few weeks ago. Because of my mobility concerns, I cannot fix it myself, which is a shame, so all I'm wanting to know is how long it can realistically hang on working like this until it completely dies. I can't get a new washer for a couple months yet due to other obligations, so I'm hoping to get at least that long out of it.
Seriously, what bummer news.
Ryne
Funny Noises From A MT Washer
Hi Ryne, since you can not easily repair this yourself and it sounds like you may replace this washer in the next year do nothing and keep using it.
The noise you are describing does not sound fatal, it may be something like the pump belt scraping on the belt guard that might have gotten bent when the washer was moved.
John L.
Sounds like it’s a very simple issue that can easily be corrected. I definitely would look into getting it fixed or you’ll have to have repair personnel on speed dial if you get a modern Samsung washer.
"You can't call for service?"
Are there still washer repair technicians out there who willingly work on appliances this old? I believe my machine is from the late 80's.
Yes there still are repair people who will gladly work on these machines but you will have to weed them out over the phone. Typically these are older techs who have worked on appliances for many years. When talking to a shop on the phone tell them that you have an eighties Maytag washer. Their response will tell you whether to book a call or dial the next number. Hope you can find someone willing to help.
