Hotpoint Toploader
Many years ago I had one of those Hotpoint top loaders purchased second hand when I was a student. It was a deluxe model with variable thermostat which was faulty so would not shut off the heater so we used it manually selecting a temp and once water was hot enough turned it to cold and then the wash cycle would continue.
Anyhow on my model it had an Economy setting which meant it filled with the hot water but the heater stayed switched off. Being about 20yrs ago I don't know if there was a thermostatic mixing valve which would control the hot / cold water mix dependant on the cycle or not. Anyhow the point being is that the economy setting maybe better than playing with the cycles.
Euan
Euan
