How Often Do You Clean Your Coffee Pot? And what with?
launderess
Jul 22, 2004
20,728
Was time to clean a bunch of those Silex cloth strainers. Usually use each two to three times then chuck it into jar until either run out or have enough to bother washing.
Anyway decided on a bit of adventure; used some of that Ecolab solid dish machine detergent. It's mostly washing soda and sodium metasilicate which are both used in commercial laundry when a high pH is wanted to "break" soils from fabrics.
Being one consumes brew made with these strainers am restricted to what can be used. Borax is out, so is anything laden with SLS which is most "delicate" detergents. Usually just soak with a bit of oxygen bleach, then boil in fresh water and same.
Mixed up some of the Ecolab solution and poured it into jar with strainers. Can you say "yuuuuck"! Water turned at once to a deep dark mucky coffee brown. About an half hour later water was even more grossly dark. After rinsing and boiling, then drying figured might as well go for a mortgage and clean the SS vacuum pot.
Made up another Ecolab solution, poured it into lower chamber, topped things off, then placed upper globe (with stainer fitted) into pot, turned on heat.....
Once water began rising to upper chamber it was a gross dark brown. After simmering for five minutes turned off heat and allows solution to "vacuum" down.
Well what a difference in the upper chamber! It the SS was bright and shiny as if it had been polished. Removed that bit and dumped out the mucky water from lower chamber and again interior was bright and clean. A bit of rubbing inside both with a sponge then rinsed and both looked good as new.
Haven't done this sort of deep cleaning since pot first arrived from eBay a few years ago now. Here's me thinking a good scrub after each use took care of coffee residue.
Seem to recall there was a product called "Dipit" that was made for cleaning coffee pots. Haven't seen it in ages though, and IIRC it was mostly sodium percarbonate.
I've used that Dip-It product mostly to clean perks found whilst scrounging through the belongings of the departed or dispossesed. I don't think it's made anymore, alas...
After the initial cleaning, just a good washing out with dish detergent (I tend to use Dawn) seems to do the trick. I don't use a scrubbing pad, just a sponge or a dish brush.
I've used dishwasher detergent from the local dollar store (I think someone here suggested that) and it seems to get the oils and residues out of a regularly-used perk also.
<span style="font-size: 14pt; color: #008000;">I think "Dip It" looks like this now. Amazon has it. I use it in my Capresso drip coffee maker and it's still works perfectly after almost 20 years. I think it's much more effective than vinegar and it doesn't make your brewer smell like a hot salad. As far as cleaning the thermal carafe, I give it a good overnight soak with half a dozen Polident denture cleaning tablets.</span>
Same routine as Harley for my drip machine, except less frequent.
Usually run vinegar through it once a quarter, dishwasher for the funnel and carafe once-a-week.  I wish there was an easier way to clean the chamber that holds the cold water but it's built-in and not removable.
My coffee production process is simple - boil water in a kettle and pour it through a paper filter and cone into my Melita pot.  So, cleaning is also simple; I wash the carafe with Dawn before each use.  Occasionally I will swish it out with sudsy ammonia (it wipes out the grease and rinses very clean).  An additional step is to polish the carafe with Bon Ami and my fingers followed by Dawn and rinse.
lawrence
My Cuisinart Coffee machine:
Get's cleaned as follows.
After every use the carafe and lid as well as the filter basket and it's housing go through the dishwasher with Cascade Fryer Boil Out. While I have very soft water due to my EcoWater EWS-3500 water conditioner I still run about 1 liter of white vinegar followed by 2 full pot rinses quarterly.
Mi Lady should be very careful when using those Ecolab solids outside of a dishmachine dispenser. They are very potent and can easily damage skin or eyes on contact. ESPECIALLY Solid Power! That stuff is loaded with caustic soda.
WK78
I have a Cuisinart DCC-1100 drip coffee maker. I clean it quarterly with 30 ml citric acid powder dissolved in a full (12 cups) decanter of water. My drip machines typically last over a decade with this regimen. Mid-range and higher Cuisinarts have a built-in "Clean" cycle, lasting about an hour.
https://www.cuisinart.com/shopping/appliances/coffee_makers/dcc-1100
Unfortunately a product very rarely seen that's as easy as brewing the pot with it in it!
That's this product carried at a few of my local hardware stores, of which I'm at the mercy of Amazon keeping around if I ever need, C.G. Whitlock's Kaf-Tan #1...
And I think that it's actually made by the same people who made my percolator, Top's Mfg. in Danbury CT.
-- Dave
https://www.amazon.com/KAF-TAN-Coffee-Cleaner-Remover-Packet/dp/B000RZLIFE
@brainardcooper
To clean the inside of your Corning Ware Percolator, fill it with water to the max level of cups, put the heating element, pump tube and basket in the the pot and add either one dishwashing detergent pod or 1-2 tbs. of powdered dishwashing detergent to the basket. Plug it in and let it run through a brewing cycle. When the perking stops, unplug the pot and let the cleaning solution remain in the pot for 30 mins. Now pour out the dirty water, and it will be dirty, and rinse the pot and parts well with clear water, done.
You can use this same process with any other percolator, either electric or stove top, as long as it isn’t aluminum, as the dishwasher detergent will make the aluminum black. If the pot or basket assembly is made out of aluminum, use Cream of Tarter instead, following the same procedure as above. Cream of Tarter won’t blacken the aluminum.
HTH,
Eddie
