rphair
I just moved into a flat in India which definitely does not sport a "classic" clothes washing machine like I see elsewhere on this forum... but the conditions are "delicate" and the machine is rather old so I hope this will still be of interest.
Typical "top load" fully automatic washing machines in India don't have a water intake pump, and the water pressure in my case is too low to convince the machine that water is entering fast enough.
I got the idea of putting a water pump immediately between the water supply and machine's intake to boost the pressure... but local plumbers don't want to get involved in what I would have thought would be a common problem (many flats are at roof level and have only a trickle of water pressure).
So I have to choose and probably install a water pump myself, and wanted to check what I should be looking out for when choosing & installing an "amplifier" pump for the clothes washer:
1) Would there be an "aquarium" pump that would provide enough pressure? The machine is designed for max 6kg (13.2 Imperial pounds) laundry with a maximum water filling of 60L (15.8 gallons) into the drum. (These "aquarium" pumps can be found at some breadcrumbs around the Amazon page linked to in this posting.)
-- The main liability of this kind of pump is that the inputs & outputs are much smaller than the 1 inch (or maybe 25mm) diameter screw fittings that go into & out of appliance taps in India (I assume based on the British standard).
-- Also most of the cheaper pumps are generally "submersible" (having no water pipe intake) or don't have safety features like "dry run protection" for when the weak water pressure trails off to zero.
2) The next level of pump power is targeted at sprinkler systems, and all have specifications that should fill 60L in the first few minutes of a wash cycle. I was happiest with the pump at the post URL link, but the local plumber said "this is only half of the pump" and I have just no idea what he means by that.
I'd expect this pump to work, as in a common application, by screwing between a 1 inch garden hose and a 1 inch input to a lawn sprinkler. Likewise I imaged it could go at the water input to the top-load washing machine, turn on & run whenever needed, and solve the problem completely.
So what am I missing? I am concerned that there's no such item on Amazon India sold as "supplementary water pump for a washing machine" given the huge demand there would be for such a thing. Any advice about how to assess this DIY job would help a great number of people here.
As an Amazon Associate we earn from qualifying purchases.
