As Chris (Gizmo) mentions - DO BEWARE OF ALL METAL EDGES - in particular the edge of the back panel, once the removable panel has been removed to reveal the back of the drum.
The edge is pretty much razor blade sharp and, if you arent careful, you will cut yourself BADLY.
Maybe best wear a pair of gardening gloves or something, till your discover where the dangerous edges are.
95s bodyshells are modular in construction:
- remove the lid.
- remove the powder drawer, by pulling it out to where it stops and then giving it a sudden yank to get it over the stop - when giving the sudden yank DONT be holding the drawer by the facia! It will probably break!!!
Hold the drawer by the drawer itself, with one hand on either side.
Removal of the drawer will reveal screws holding the facia to the bodysell at the left hand side.
- look at the programmer from the top and you will see a gap in the moulding of the facia. Through this gap you will see the shaft of the actual dial - turn the dial till a screw appears.
Turn this screw anti-clockwise to loosen the screw and then you can pull the dial away from the machine.
Removal of the dial will reveal two small screws - these hold the facia to the machine at the right hand side.
- Remove the screws, that have been revealed through removing the powder drawer and the dial, and the main facia can then be removed.
- This will then reveal three screws, which hold the main front panel to the machine at the top.
From this point, go upto Gizmo's instructions and you should be OK.
Good luck and BE CAREFUL!
Paul
p.s below is a scrap 9524W, that I picked up for a tenner a year or so ago. It cleaned up so well that it is now a preserved machine in the safe hands of another collector.
Hotpoint 95's are still all over the place!
Get in with a local shop that takes in scrap machines or trade ins and see if they can source you an old machine for parts.
