huebschman
Water on the floor... checked behind the machine and everythin' "seemed" dry. "Shit my Huebsch is leaking"... I was pi**ed off... False alarm, it was the cold inlet hose. This is just a reminder to you all. Follow the manufactures instructions and change your hoses every 5 years. And don't think you will get longer millage with braided stainless steel hoses. In my case, the hose was not at fault. It was the (sorry, don't know the english word) the "twisting thing" at both ends that had corrosion problem (original Alliance hoses). And furthermore, close your valves after each use. To leave a hose under pressure in your home is not a good idea. My downstairs neighbour is happy I did that...
