Hvac nightmare am I being ripped off
Toggleswitch2,I am TERRIBLE at grammmer sorry.Yes we spent 4 grand on the power.Our house is 50+ years old.They had to redo everything from the transformer to the house but we had a larger than average box because we have a cottage in the back.Yes we had cheaper quotes alot cheaper but there is some politics in the mix from the city inspector.Its a long story.
~I don't like gas heat cause it dries the air so bad.
I'm gonna debate you on that one! *LOL* Prove it!
GadgetGary has a heat-pump, in Connecticut, in an all-electric house. It works just fine and defrosts just fine.
He used an older air handler and (refrigeration) coil with a new outdoor unit, and the old refrigeration lines. No problems for years. Last summer the automatic thermostatic expansion valve quit and it took us about half a dozen guys to look at it. None knew how it worked. Finally a "commercial" system guy came out (one who knew about TEV (Thermostatic Expansion Valves) and replaced the head of the valve and sensor bulb and tube...it was so easy I could have done it myself. But who knew?
My pont is, in Connecticut a heat-pump is a foreign and rare beast and HVAC people FEAR it! I hovered over the fools and watched everything they did. A few admitted they know A/C's but not heat-pumps. Bye-bye they went!
Lesson learned: Me likey two independent systems or good back-ups. I got Gary's basment electric forced-air wall-heater up and running after replacing the circuit-breakers and adding a wall-thermostat. MAy not be needed but it comforts me to know it's there for an emergency.
Heat-pumps are interesting but seen as complicated. Remember guys, there are electric strip-heater cut-out controls that prevent electric resistance coil heating from turning on except during defrost or tempertures outdoors of below ___*F. I added a swich in series with the "call for electirc heat" wire coming off the thermostat. In this way the system can call for eelctic heat during defrosting, but not at any other time without manual intervention. His system is sized larger than his neighbors in that he has a fully finished walk-out basement that is used as living space, so he doesn't need electric back-up until about 10*F outside or below.
Well all the Heatpumps here when you bump the T-stat up more than a few degrees it brings on the Em heat automaticly.I will have that locked out so unless you press the button for it.I am oversizing the unit just a little because its a Two-stage scroll so it will heat better.The reason our furnace is so drying I think is because the everything is up stairs in the attic and they oversized it.I think I will go for the Dual-fuel unit on the Ruud so I will have four or five stages of heat.The furnace/airhandlers have 3 stages on some but its confusing nomeclature on the spec's. My Aunt lives in Vermont she has a fasinating Heat-Pump its called the Acadia from Hallowell.Its not a in ground Job its a Air source but it has two compressor's the main one and a booster.
American Standard
Last year I bought a 5 ton American Standard. HP. The quietest thing I've EVER heard. When it starts,the compressor starts first, then the blower starts on low and within 2 min. it's at full speed. Then the compressor stops and the blower stays on for 2 min. Then completely stops. And they told me that it is rubber mounted so it doesn't shake.....Bill in Az...
Mine is a Rheem Classic.. Chepo builders unit.. Cost me almost a grand to fix it... Next time it breaks, out it goes and in goes an AM Standard
