Oh well
I hooked up the 1-18 washer after work today. I have it out in the storage shed (thankfully). So, I purchased 20' of drain hose & a "Y" coupling so I could connect the outside hose. All went well. I set the water level to the lowest setting to begin with. When it started to agitate all went well but then the leak began. It was leaking a lot! So, I put it on spin which was uneventful until I started seeing smoke & smell a burning kind of smell & then the spin shut down & the washer wouldn't operate at all: no fill, no agitate, nothing. I decided to let it sit for an hour as most of the water was extracted. When I came back I plugged it in & the spin kicked in & finished the job.
So, I can tell there are 2 problems: the leak and when it is spinning there is a very loud rumbling/roaring noise.
I will next take the front off & try to find the leak. Does anyone know about the loud noise? Any ideas would be appreciated.
