So I thought I would post this here in case anyone was thinking of buying the Samsung DW7933LRABB dishwasher.
I have had the displeasure of owning this dishwasher for about 6 months now and I hate it! It does not clean well at all.
The water in my area is pretty hard so I have tried every detergent on the shelf thinking it was a problem with the detergents I was using. I have tried every cycle combination (with and without the sanitize option) and still have food particles left on dishes after the cycle completes.
Dishes get scraped off into the trash before loading, cookware and utensils get soaked in hot soapy water and practically washed by hand after use and still do not get cleaned in this thing.
I have found that Finish Power Ball tabs and Cascade Complete pods work best in this dishwasher with my water, but I have to turn the rinse aid dispenser to "1" (I have been using Lemi Shine rinse aid because this dishwasher does not rinse jet dry off of dishes well enough, EVEN, if the dispenser is set to "1" so you end up seeing bubbles when you fill a "clean" glass with water) so I don't end up with residue and spots on glasses. This causes a problem though, because without enough rinse aid the dishes remain wet after the drying cycle. My old 8 year old BOL roper dishwasher would clean ANY load perfectly with even the cheapest dishwasher detergent.
Also, the tines on the bottom rack are too close together making it difficult and inefficient to load large bowls, pots, and pans. The detergent dispenser is also way too easily blocked.
Top rack loading is also a joke. Bowls do not set properly unless the top tines are "angled" outward, but this reduces the amount of space for other items such as glasses and misc. items. Another issue is that the wine glass holders do not work very well and allow the glasses to rub against eachother because the edge of the rack slants downward.
I have tried loading the dishwasher like the manual advises but results are the same...Poor at best!
No, the filter screen is not clogged.
No, none of the holes in the wash arms are clogged.
No, I am not choosing the wrong cycles (Again, I have used every single cycle on this machine... Smart auto and Heavy Duty are the only cycles that somewhat work).
No, I am not over crowding the dishwasher. (It is only a household of 2 and loaded and run nearly every evening)
No, the incoming water temp is not too cold.
No, I am not using too much rinse agent.
Yes, this dishwasher sucks.
I know the racks are adjustable but they are not "flexible."
Unless you want to wash clean dishes with your dishwasher, or use it as storage, do not buy this unit.
I thought I was "upgrading" to a better dishwasher. NOT!!!
Oh I almost forgot This thing is pretty darn quiet while its running and NOT cleaning my dishes.
