iheartmaytag
It was a have to situation.
As I had written before I was researching replacing the basement toliet that shows a date of mfg. 6-11-71. I have been dealing with an off and on leak for quite some time. The tank appeared to have had a crack that the former owners had epoxied at some point in it's life.
This weekend the bolt had rusted through and just fell out flooding the floor. So I went to Lowe's with the intent of replacement, but the guy told me you can just purchase a repair kit $2.49. It had a new tank seal and bolts with seals. Went home and gave it a try. Everything was fine, until I went down a few hours later and the floor was wet again. There was a leak around the epoxied portion where the bolts went through to the bowl.
So I took the tank off again and put a larger rubber seal around the bolt and went to bolt it back on. I was tightening the tank bolts down and noticed that there was still a wobble so I turned the wrench one more turn and SNAP!! The whole back of the bowl snapped off.
So I went back to Lowe's and bought a new toliet. I had been doing some shopping before as I stated, and was dead set that I was going to buy something that as not made in China. So I opt for an American Standard with a 10 flush rating and 1.28 gal per flush. Lugged it home and as I am unboxing.
HERE COMES MY RANT.
On the inside box, not the outside mind you, the inside packing it said. "Made in China and Mexico from USA design."
There should be a law.
The toliet works fine, quiet, cleans the bowl, and since it is connected to an ejector pump I don't worry about the sewer line. I just burns me that you can't even buy a crapper made in America.
HERE COMES MY RANT.
