Affresh works, no doubt, but I found a much cheaper washer cleaner. It's just standard dishwasher detergent powder and about a cup of bleach.
Before I get started on the clean cycle, I use Awesome degreaser and swab the door seal. This aids in removing any grime.
I then start the cycle. Even though my machine has a clean cycle, I use Bulky/Bedding on steam as it uses a bit more water than the clean cycle. The dish detergent is added first, about three tablespoons worth. The dish detergent, of course, takes out any soap residue and grime. The bleach is not added to the wash portion of the cycle so it doesn't hinder the cleaning ability of the dish powder.
On the rinse cycle, let the washer fill and then add 1 cup of bleach. The bleach sanitizes the tub and rinses away the dissolved soap deposits. Because I leave my door wide open after use, I don't have a mildew problem, but this could also finish off attacking mold and mildew after the dish detergent.
After the second rinse cycle, the water should be crystal clear, which should mean the washer is clean.
