Sadly, Miele does not market a snowblower in the US, so I'm stuck with an MTD, which has failed me today.
It finally snowed enough here to get out the snowblower (I clear my driveway, a neighbor's, and my elderly grandparents' as well as all sidewalks. I dug the snowblower out of the shed and it would not start. I had to drag it from the shed to the front of the house (NOT fun in the snow on grass all the way across the yard). After futzing with the thing, I found, among other things) the electric starter to be faulty. I removed the starter, lubricated the shaft, (the starter's shaft) and reinstalled it.
Good news! The starter now functions properly.
Bad news! The starter cranks fine and I can get the engine to fire, but it only runs for 1 or 2 seconds, then dies. It will only do this after priming (pumping the bulb). Messing with the throttle and choke don't improve the running time. I am guessing that the engine is running on the fuel pumped up by priming and that it dies when that is gone.
Yes, the oil is good. The fuel tank was dry so I put in some fresh gas. There is fuel in the carburetor bowl, but I don't know if it's old fuel or new fuel. The fuel line valve is open. I checked the spark plug and although it is a nice shade of black, it has enough life to fire the engine a few times.
The engine is an 8 horse power Tecumseh HMSK80, and the entire machine dates (I think) from the late 1990s or early 2000s. The machine has seen light use.
Oh great problem solvers of appliances! Please grant me your wisdom so I may get this contraption running. I have already run out of swear words, so either tell me how to fix it or start making some new words for me to use!
Thank you for your assistance,
Dave
Note: My A208 is on hold until warmer weather after I have fixed the snowblower
Also, My father is in charge of snowblower maintenance (translation: none, and the reason why he drives a new car and mine is 20 years old). He is away so I have to fix it (the snowblower).
Dave
