I guess the huge discount is because you have to clean it yourself? I also love the line "its a 40in range looks almost new there is two chips on the top, and the drip pans need to be cleaned good."
Well, then it doesn't look "almost new" then, does it?
Second photo is when the control panel shorted out. Front unit that went out is probably the Super Corox flash heat unit. BB is one oven deluxe, next to the double oven TOL. The platform light came on when a surface unit was switched on to light up the heat level color wheels around each switch. I hope it has wheels because at $200, that is the only way it's moving.
