whirlpool862
Lately one person has been defending GE’s HydroWaves and their Model-T machines, but they were terrible machines.
I’d much rather even use a Samsung machine than a GE HydroWave, at least when a Samsung gets off balance it’ll redistribute, while a HydroWave will destroy itself before of the lack of balance sensors.
I’d much much rather use a modern VMW Maytag than any GE HydroWave.
I’d also much rather use the newer GE than the HydroWave. The newer GE’s, when off balance, redistribute the load, while HydroWaves will just destroy themselves.
The mode shifter was also a common failure, whether it was the bearings or the coil. Either it would wash the whole drum, or the bearing failed making it really loud.
The DAA ones and the infusor ones both didn’t clean properly, but the Infusor variant of the Hydrowave was even worse.
The reason why bearing failure was so common with these was the upper seals often failed, causing water to leak down into the bearings. The HANNING pumps on the HydroWaves and Model-Ts were rather loud as well as the motor.
Another common failure with these was that the washer would often rub against the bottom, causing it to make a loud scraping noise on agitation modes.
When the more shifters failed, it often caused it to bang or squeak on agitation.
When the mode shifters worked, it sounded like chains rattling when engaging.
Some people even reported stories where their HydroWave got so out of balance that it flung the cabinet of the washer open or made the control panel fall off.
Another common failure of the Hydrowave or motor T was if the overflow tube got clogged, it would flood your either house. On a modern Whirlpool VMW, the washer will drain out the excess water by running the pump.
There were also issues with the inverter motors where the internal bearings of them would fail, causing it to make a horrible noise on spin, or the inverter motor failed.
They also used this system on commercial washers, which was an otter disaster because this system didn’t even perform well on a residential setting, let alone a commercial setting.
Overall, the HydroWave was one of the worst washing machines GE ever made, after just 3-6 years, the mode shifter often failed. They also didn’t have good cleaning performance and they weren’t that quiet on a spin cycle.
