If CommodoreJohn`s washer is the Chairman
I have this washer exactly, it's a pretty good little washing machine, uses plenty of water!!! Mine just has a spin issue, it appears that the tub is not connected to one of the legs of the spider assembly...
I have this machine as well at the lake house. It works well, does use enough water. Just be careful of coins. They seem to go right into the pump and create a grinding noise, and limit the draining.
Oh bpetersxx, I wish you HADN'T done that!! Now I need to get one. What model No.? And yes, the EMPEROR will do. It's not a washer-dryer combo is it? The Haier combo machines don't dry well at all I've been told.
Its a Haier xqg50-qf802
My other Haier front loader combo is out until I can pull the bearing out and replace it
The combo will not dry very good even with a half load
Here are my 2 frontloaders doing tests on them
I got these from a salvage company the 802 looks like too much weight was put on it and the corner collapsed
But it washes just fine with lots or a little water
I tinkered with the pressure switch
The washer in the left of that pic with the square door, looks remarkably like an Indesit from over here!!
Really reliable machines over here!! I had a model from just before this range and one from just after LOL..
Happy Washing!!
