If the normal cycle on dishwashers had the high temp wash option locked on by default, it would be easy to just push normal and start. My 2007 whirlpool has the heat dry as the default to normal. I just push normal, high temp, heat dry to turn it off and just hit start. It would be better if the high temp wash was the default to the normal cycle! Dishes come out much cleaner than with just normal and heat dry. What do you think? I just use normal and high temp wash! That's all I need! And yes, I do use rinse aid! As a side note, I noticed that the spray arms speed up when Cascade rinse aid is used in my 2007 whirlpool.
