if speed queen created a tc 7 what features would you see on the tc7
if speed queen created a tc 7 what features would you see on the tc7?
  • Total voters
    7
If we did, I'm sure it'd be somewhat similar to what the 8 or 9 Series has. Agitator separated from the tub, cold rinse only, load size, open the lid at any time, unfortunately very expensive, no mechanical timer (heard from someone at Alliance that the EPA requires all washers to be electronic), there'd be an extra rinse, a soak feature, have the classic old school motor, and some other features that the 8 or 9 Series had like the spin only cycle. As much as I'd like to see a TC7, I honestly don't think it'll ever happen. But, you could however buy a new LWNE22SP115TW01 model and convert either a 8 or a 9 Series board onto it.
https://automaticwasher.org/threads...l-washer-to-a-2017-sp-residential-unit.78063/
https://automaticwasher.org/threads/you-can-truly-have-your-speed-queen-cake-and-eat-it-too.84952/
Personally an ideal Speed Queen would be:
1) A dual action agitator
2) 3 Speed motor
3) Ultra Clean cycle with up to 16 minutes of agitation, auto soak, pre-wash that leads into Ultra Clean
4) A separate permanent press cycle with cool down half a tub drain and re-fill.
5) 30 second spray rinse in the first spin and a 30 second pray rinse in the final spin
6) Temp control with 12 settings: tap hot / warm, warm/warm, hot/cold, warm/cold, cold/cold, ATC hot / 70*F warm, 120*F hot / 70*F warm, 100*F warm / 70*F warm, 70*F warm/70*F warm, 70*F warm / 60*F cool, 60*F cool /60*F cool, 60*F cool / tap cold.
7) Advance from soak to pre-wash to Ultra Clean on or off.
8) Speed selections fast/fast, slow/fast, slow/slow, extra slow / slow, extra slow / extra slow, intermiment extra slow / extra slow, fast/slow.
9) Porcelain coated top and cabinet.
10) Sound depending.
Ideally I'd prefer this in an EM control, however being a TC7 I'd imagine it would be an electronic touch pad control.
Since, I have a TC 5, I would request more water levels: Small , Medium, Large and Deep Fill. On the selector you currently have Extra rinse, Extra rinse with pre-soak and Heavy duty which adds some extra time. So since I always used extra duty, provide a separate button just for heavy duty (extra Time) or extra selector choice for heavy duty with extra rinse. Finally, provide option for either a warm or cold rinse.
