rollermatic
i got the hydrosweep pump back in the water a few weeks ago, actually the day before i had funkie put to sleep due to cancer. i wanted her to see it for some crazy reason.
but i had to make some much needed improvements. by the end of last summer the 4ft. diam. board that it is mounted on had become waterlogged and it sank about 8 inches under the surface. only the top of the hydrosweep was still sticking out and it was at 30 degree angle.
so i made buoys out of 2 inch pvc pipe to act as a floatation device for the assembly.
here are some pics for anyone interested.
here is the platform upside down, pump detached, with the 4 pvc buoys attached side by side. obviously i sealed them tight with pvc cement on the end caps and hopefully there are no leaks.
