In regards to drying…
adam-aussie-vac
Dec 14, 2017
1,002
Canberra ACT
Hey guys I’ve got a question for you, what is more efficient /dries faster?
As my mum always tells me “only just put the things that you need tomorrow in the dryer but I feel like that isn’t really efficient because there’s a whole tonne of heat produced and probably most of it would be Going out the exhaust, hence why I’ve always done mainly a full load of stuff to dry instead of just one or five items I need for tomorrow
my advice
my advice is if you can line dry or have a clothes rack like this for small loads if its day time line dry or if its something you need for the next day then use the clothes rack and use the dryer for bigger load unless your dryer has a time dry cycle that you can set for 30 0r 20 minutes or less depending on load size
I tend to do my laundry in the late afternoon,
Previously when I got home from work, it would be washed and rinsed and then spun through a extractor, and then after that depending on the dryer that I’m using The time varies from 30 to 45 minutes or to 1 hour and 10 and one hour and 30, The reason why that I thought it was less efficient to dry a single item Or five items, compared to drying a full load. Is because most of the heat would go past the items to be dried instead of being used to help Evaporate moisture in the laundry being dried
After the twinny spinny I hang towels over the showercurtain rod.   By the time everything else is done they are dry enough to use (if a bit clammy).  The dryer finishes everything off in 15min.  Except socks, which get to lay out till the next afternoon then put away.
In Hawaii, never had a dryer, never missed it.
<span style="font-size: 10pt;">But half the time in Hawaii I scarcely had clothes either.</span>
Yeah, under an hour ... 34 mins total.  25 mins to start of cool down (3:48p to 4:13p).  End-of-cycle 4:22p.  100% dry, no redistribution.  Those crazy F&P machines ...  ;-)
