Inglis/Whirlpool/Kenmore/Roper switch bypass
Its simple!
Remove the two plastic endcaps from the control panel. Underneath, you will find two screws-one at either end of the control panel. Once you removed the screws, the panel will flip up and back. Now you should see a plug with three wires-one grey, one green and one tan. The quick and easy way is to cut the grey and tan wires, then strip and splice them. Disregard the green wire (its a ground) and now you have bypassed the silly safety switch.
If you have little kids at home, you do this at your own risk!
