inlet valves
christfr
Aug 25, 2002
1,789
st louis mo
does anyone know where to find rebuild kits for the old style water inlet valves? or is it just easier to buy the new style and make them work.
Probably easier to retrofit a new valve. I haven't seen a rebuild kit since Allied Appliance Parts blew up. (Oh, it isn't that bad-I have seen 'em. it's just so much easier to go with a new one)
Greg is that kit for the large style rubber seats or the standard size rubber seats? I'm thinking Chris might mean for the large style rubber seats which I don't believe are made anymore, but I could be wrong. It would be great to get rebuild kits for the really vintage valves.
Normally I just replace old valves with new ones, but if there is a flow washer in the output of the valve, you need to take the old washer out of the old valve and install it in the new valve. The flow-washer slows down the rate of fill for solid basket washers in order to prevent overfilling.
