1953 Hotpoint dishwasher. I got a "new" timer motor installed but the inlet valve is still not opening. I have done some troubleshooting and think the timer, inlet valve and its circuit is fine. I believe the problem is the "measuring coil" is not allowing the inlet valve to open. Does anyone have any idea of what I try next? The manual says if the measuring coil is bad the entire connection box along with the coil must be replaced.
Note: When a current is applied to the inlet valve directly (hotwired) it opens normally. This is why I suspect the measuring coil.
