Introducing The AEG 46200 TopLader
You can see, well you can see the inside is not
Quite clean. Will sort that out presently soon as some other issues are attended. Am going to give the boot and upper areas a good scrub with disinfectant cleaner, then run a rinse only cycle. This followed by a boil wash with vinegar should clean up any other muck and deal with a rather strong pong coming from tub.
Am guessing the whiff was caused by machine being unused and shut up (tsk, tsk, tsk), but that is small beer. Will also have to take out lint filter to see what there is down below.
Have long ago made a vow *NOT* to rush out and buy new things each time something arrives. Thus spent a good part of yesterday hunting down long ago stashed spare hoses, clamps, and so forth. European washing machines have different hose fittings (found that out when the Miele arrived many years ago now), but recalled having a job lot sent from Europe for the AEG OKO-Lavamat. Question was where did one put the things?
Other issue is that the AEG Electrolux uses that blasted AquaStop type fill hose. That will have to go eventually. But was glad previous owners sent it along so just needed to fit an extension hose with proper faucet coupling, so that's me sorted.
All and all an interesting bit of kit from Electrolux.
You can see how the lid does not close fully. One supposes that is to allow machine to air out between uses. All one need do is press gently and lid locks.
Downloaded manual but since have the OKO-Lavamat things aren't that much different. However Electrolux did make some changes along way.
"Zeit Sparen" is the "time saver" button. Same as with my other AEG one uses this to shave time off cycles. Maddening thing is manual does not give cycle times; merely says "refer to machine".
This model does not have a "Sensitive" function. The 46210 does, but that is a minor niggle. More so because unlike my OKO-Lavamat this machine does not allow use of "Rinse Plus" and Sensitive. The latter did so for "Cottons/Linens", and a few other cycles. However those which already had high water usage (such as Delicates) didn't allow.
One can open this machine up to ten minutes into cycle. One knows from old that amount of time is allotted by AEG to heat water. Thus one assumes to prevent scalding or whatever once machine reaches temperature it is "locked".
Another minor issue is lack of "20C" (no heat) option for normal and most other cycles. There are times when doing say a warm, or cold wash that don't want the bother (nor expense) of using machine's heaters. But guess Electrolux thought different.
Thank you Louis
Recall asking your advice about the other older AEG toplader was after, so am reassured you find this model more suitable.
A quick search on internet saw there are tons of parts still out there for this machine, even directly from Electrolux. But since they won't ship to USA will not even bother contacting.
Manual goes on about something called "Night Plus", but don't believe this model of toplader has that feature. My other AEG is dead quiet except at highest spin speed (1800), thus am curious as to what Electrolux has up their sleeves.
Drum is *huge*! Can see why Electrolux claims this washer holds 12lbs. Am not going to test limits, heavy things like blankets will still go into the Maytag wringer.[this post was last edited: 6/17/2018-10:50]
You are most welcome !
Also while perusing the net try Eurospares and any other supplier if you need anything they do not have its worth asking on here in case any of us lot have it stashed in a box I have some Miele bits and pieces I have stored and so far not needed :)
Austin
This is the AquaStop hose in question.
Interesting and useful bit of information is that Electrolux for some insane reasoning has parts for AEG, Zanussi, Zanker, and Privileg.
This means depending upon age of machine in question if a part cannot be found for say Lavamat, it might be as Zanussi, or Zanker.
In any event the water hose must go because it requires faucet with screws on outside. Also Electrolux does not recommend use of extensions (scrub that), and hose only comes in one short size. Went through this with the AEG Oko-Lavamat and thus already know one does not *need* this silly hose. It will remain for time being, but am making plans to replace.
Good luck and many happy hours of washing with your new addition!
Not sure if this has been discussed before, but I`m curious about the one paddle design.
How exactly does it work with only one paddle or is there something else hidden under the lid we can`t see ? It`s not spinning the drum three times faster during wash and rinse agitation than a "normal" drum, is it ?
There is no comparable FL with only paddle out there, is there ?
How can you trust a very unique washer design if there is no youtube video out there to judge it before you buy. I couldn`t *LOL*
Like many modern European appliances of recent days this machine won't run on anything but 50hz. She hikes up her skirts and runs from anything else! *LOL*
Previous owners living in a rural area used a generator throttled down a few pegs. Obviously that won't go here; so a friend is going to supply a frequency converter.
Sadly the device for now will only give about 1.5kw, barely half of required. But am simply going to dispense with allowing machine to self heat water. Supplied voltage should be enough for everything else. Would require a frequency converter in excess of 3kw, which while easily found, would be nearly size of machine and cost sums equal to a new Miele W1! *LOL*
Between the Miele and OKO-Lavamat am well sorted with washing machines that do profile, boil washes and so forth. Then have several boiling pots that can be put on range; so that's me for you.
We all have to make do sometimes. Machine was free so that is something anyway.
And having lost out on the other AEG what could one do? Have fancied toplader H-axis washers since first visit to France years ago now. [this post was last edited: 6/18/2018-04:42]
@ Mrs Bucket...
What does the 'Energiesparen' programme do (11 O'clock on the dial)?
I imagine it saves energy. Could it be a 'no heat' programme?
If push came to shove, I suppose you could connect the hose to the hot tap and allow the machine to fill and wash with hot water, then later on switch the hose to the cold tap for the rinses. You might have to use the lowest temps though, so the sensors don't try to switch on the heater.
Energiesparen
Is indeed "Energy Savings" programme.
AEG has offered it for some time, as my OKO-Lavamat W88840 has same cycle as well. Wrote about it at the time in a thread about my (then) new machine.
Basically cycle is supposed to give 140F wash results but using less energy. Does this by using less water (recirculating jet sees heavy use) during wash and taking ages (about two hours for the wash IIRC). Only did it the once to see what there was; then that was that. Suppose if one were wanting to do a wash overnight or otherwise didn't need the machine for several hours....
Thank you for suggestions regarding hot tap water. Have done that with the OKO-Lavamat say for laundry that was pre-soaked prior, thus didn't need a "profile" wash. Have a stash of AEG/Electrolux service manuals so am studying to see if these newer machines will have it; that is simply not turn on heater and get on with things if water temp is sensed to be within range (or over) whatever is desired already.
