I had daunting task ahead of me. When I installed a window in our 1957 KitchenAid the interior door of that machine was much less complicated as all of the controls were located on the lower panel and there was no dispensers.
Here is what I had to do to this machine in order to cut out the door and install a large picture window...
First I removed all of those componets in the previous picture and used my jig-saw and cut and large square hole. Then I used 1/4" thick glass and siliconed it to the door. I secured the glass with seven rubber mounts that have a light screw pressure up against the glass.
There they are all installed. I plan on using detergent tablets as obviously I wont be able to pour powdered detergent into the detergent dispenser anymore.[this post was last edited: 8/28/2011-15:06]
Here is the left side of the machine. I added another vent on the top of the machine as these early models didn't have a blower so the drying ability was just fair. The extra vent seems to really help. It's made out of an Asko washer detergent dispenser hose. Works well and no leaks.
All done and installed, the I hade to cut two 1.5" side panels to take up extra space and fit this 24" dishwasher in a 27" space. The 1953 Hotpoint that used to be here was 27" wide.
Way Kewl Robert. You "da man"! We had a 1971 Lady Kenmore from 1985 thru 1990,for only 25.00,then had an UltraWash from 1990 thru 2009. The LK was alot of fun,liked it alot!
I wasns't sure how you were gonna pull this off completely, but you did a stupendous, amazing, wonderful job!!! Is the Hotpoiknt going in the basement and will it still be usable?
