Is this a Bob-Load?
washingpowder
Mar 2, 2014
150
NYC
Wish I snapped the 'before' pictures.
There was burned-on bechamel, chocolate pudding, scalloped potatoes, ratatouille, you name it.
No pre-rinsing.
Miele G894 and Method Smarty Dish got it all sparkling.
Two photos of lower rack since there were two 'layers' involved.
Nice layering on the bottom, good use of the coffee bar in the middle rack - so many guys don't use that.
So well done you even had room for 2 more cups on the middle rack side flip downs if you needed them.
Masterful.
How many re-orgs to get that state?
Uncle Dave
Thank you!
Lower rack took one re-org when a lonely KitchenAid bowl was found, that's when I removed plates from the tins and decided to create a second layer.
Unfortunately the cup racks have limited corner coverage, that's why smaller cups are positioned with some space from the front and back. Glass on the right must have moved when I was opening the dishwasher.
Honestly that's the only issue I have with this dishwasher. Otherwise it keeps impressing me.
Does sausage grease count?
While cleaning up the supper dishes last evening, I forgot to rinse the pasta bowl before loading it, and it had the saucy grease from the Italian sausage I made which spilled all over the door liner. It looked like a hot mess.
Large load, came squeaky clean with Finish power tab, and liquid Cascade for the pre wash on anti bacterial with added heat, air dry.
