Last night I kept thinking that it would be nice to have an Apple Pie for the weekend. I had some extra apples, so I took them out of the fridge before we went to bed so they’d be at room temperature by the morning.
This morning it only took me 30 mins to peel, core and slice the apples, make the dough for the crust and put the pie together for the oven.
Filling for Apple Pie
In a large bowl mix together:
1 cup sugar
3 tbs. Minute Tapioca
1/2 tsp cinnamon
1/4 tsp nutmeg
Add 3 lbs of Apples that have been peeled, cored and sliced, the juice from 1/2 lemon and mix together well with a spatula until apples are well coated. Let set for 15 mins while making the dough for the crust.
Pie Crust for 10” 2 crust pie
In a medium size bowl mix together with a fork:
3 1/4 cup flour
1 1/2 tsp salt
2 tbs sugar (optional)
In a 2 cup liquid measuring cup add
1 cup vegetable oil
1/2 cup ice water
Stir briskly with a fork and pour into flour mixture all at once and mix together with a fork until dough forms into a ball. Cut the ball in half. Roll each 1/2 of the dough out between two 12” sheets of wax paper. Carefully remove the top piece of wax paper and carefully turn the dough into a 10” pie pan, remove the wax paper and fit the dough evenly into the pan. Add the apple pie filling and dot with 2 tbs. butter. Roll out the top crust between the same two sheets of wax paper, remove the top sheet of wax paper and carefully transfer the top crust to the top of the pie, fit in evenly over the filling, remove the wax paper, turn the dough edges under, press together and flute to seal the crust and sprinkle lightly with sugar if desired (optional). Cut a small 3/4” hole in the center of the top crust, cut 8 slits around edge of pie to release the steam while the pie bakes, place on a baking sheet, cover the edge of the pie with either a pie ring or strips of foil to prevent over browning of the crust edges and Bake at 400 F for 55 to 65 mins, or until apples test tender with a toothpick and juice just begins to bubble through the slits. Cool completely before slicing.
Eddie
[this post was last edited: 7/7/2023-18:55]
1 cup sugar
1/2 tsp cinnamon
1/4 tsp nutmeg
3 1/4 cup flour
1 1/2 tsp salt
1 cup vegetable oil
1/2 cup ice water
Eddie
