It's Official - Convection Oven Beats Microwave
launderess
Jul 22, 2004
20,655
Have been using my Maxim convection oven (see other posting about having the damaged glass door replaced), and have to say am that well pleased with meats done with this method versus microwave.
Previously would do chicken pieces in the (Panasonic) microwave as have done for ages in the Sharp or others. However one day sitting down to dinner just didn't appreciated the rubbery skin MC done chicken often has and that quite allot of water escapes making the whole process more like poaching than roasting. The only chicken that really comes out well is batter and breaded coatings.
So far have done turkey breasts, rack of chicken thighs, pork and beef roasts, all coming out each and every time wonderfully! Batter and breaded coated chicken pieces pork chips are the next best thing to deep fried!
One thing have found that it is important to use a good probe oven thermometer, and make sure it is inserted properly. Convection can cook things very fast including meats and if one isn't careful you can end up with an overcooked and dried out brick.
She was a sister who really cooked
That's just grand Laundress, I haven't seen a Maxim oven for so long,now you'll need to have a cup of Maxim coffee (the spoonful rich enough for a mugfull) with your luscious chicken,lol!
We had a countertop convection oven years ago. Things like biscuits, roasts, bacon, etc all came out much better in the convection oven than when made in anything else.
So when it came time for a new stove we made sure it had a convection oven inside!
The thing to remember is the best candidates for convection ovens are those things that are cooked in low sided open containers like roasting pans, flat baking sheets, etc.
Launderess, NOW you're cooking
Perhaps I'm a purist but I can't imagine anything being remotely palatable after cooking it in a microwave oven.  I use mine for defrosting frozen items and for warming leftovers but that's about it.   I could very easily go without using a microwave oven at all but I wouldn't dream of giving up my convection and conventional ovens.  I bought the Farberware countertop oven 30 years ago and hardly a day has gone by since then that it hasn't been used with highly flavorful and visually appealing results.
A good rule of thumb when cooking meats by convection (and many other things as well) is to reduce the temperature by 25-50 degrees from what is called for when using a conventional oven or, start the cooking process at a high temp of 425-450 for about 10-15 minutes until the meat is browned and then reduce the temp to 300 until desired doneness is reached.
A convection oven is also great for dehydrating fruits and vegetables and making jerky.  I'm not a fan of jerky, but I enjoy having dried fruit on hand for snacking.  The Farberware oven has a set of fine-meshed drying racks for the purpose.
@ Ozzie908
During the 1980's or so there was a table top convection oven craze. Faberware, Cuisinart and Salton Maxim were the three main ones out there. Know that Salton/Maxim's version was sold in Canada, the UK and parts of Europe as well.
See link for picture of the Salton/Maxim model.
Roasting Meats
Have found for joints/roasts one should balance time and temperature carefully. Too low temps equates to longer cooking times which because of the dehydrating nature of air blowing in the oven interior can lead to dried out foods.
I do pork and lamb roasts at about 325F, and beef 300F to 350F. One first needs to use a good oven thermometer to get a reading of how accurate the temp set from the controls. Once you have that bit of information thing go smoothly from there. Again I always recommend using a probe meat thermometer when doing roasts.
Personally do beef only until internal temp reads about 130F, take out of the oven, tent with tin foil and allow to rest until carry over heat brings things up to 140F or a bit above. Find roasting until temps reach anything above 150F or even 160F will result in an over done roast, especially after the thing sits and the aforementioned carry over heat does it's magic.
Same with lamb, chicken and pork, though with the latter one has to be more careful to stay within ranges set to kill off any "bugs" inside as pork can be tricky.
The United States Department of Agriculture
says that Trichinae (of trichinosis infamy) are killed at 137F. When I cook pork, I take it to no higher than 145F in the oven, and when it is resting before carving, it goes up to 150-155F, safe and juicy.
The USDA says it, I believe it, and that settles it, at least for me.
To use a microwave to its best advantage, discard all notions of it being any sort of oven, and think of it as a marvellous STEAMER. I love microwaved vegetables, fruit, and fish. It is also the only way I will melt chocolate or butter.
Lawrence/Maytagbear
Austin
Those ovens were sold here too, dont recall the name - might even have been under the Magimix name or even Robot-coupe. I am sure you will recognise it yourself anyway. But its basically just a small fan oven. If I remember right, from your previous avitar, you have a Neff oven. This should give you the same result, especially of you use the Circotherm grilling setting
Al
Ah Jehane Benoit. She was a Canadian cooking icon, did tv commercials as well for different food/cooking related products over the years.
Re your Maxim.. where and by who does it say manufactured it on the plate
Best final temp for pork depends on the cut.
Of course, 145F is enough to kill trichina parasites. Interestingly, a common variety of trichina is also killed by freezing. But not all trichina varieties are killed by freezing, so it's not a reliable method of control. And one definitely doesn't want to get infected - it can cause all sorts of systemic problems.
But my point was that for tender cuts, 145F is fine. But for gristly cuts like pork shoulder ("butt"), it's recommended to do lengthy cooking with a final temp of 185.
I set my slow cooker temp probe cycle for 175F, and that seems to do a very good job with pork butt. Tender, but not so overcooked it falls apart. For an 8 lb shoulder, it takes about 8 hours to get there. Falls off the bone but is intact enough to be sliced for sandwiches etc.
Back to the original topic... I've found the convection mode on my little Cuisinart toaster oven works well for some things, such as upscale (Trident brand) fish sticks or french fries. I've seen larger commercial quality counter-top convection ovens for sale at restaurant supply sections of box stores, but have refrained from diving into that because 1) they are not cheap (over $200) and 2) I have run out of room for such gadgets, and 3) They are not "true convection" anyway (as far as I can tell).
The Best is Both Worlds
I have long bored you to death with pictures of dinners and pastries emerging from my GE Profile Convection range in great volumes and greater perfection in the finished product.  Last spring Gansky gifted me a NIB Whirlpool Convection Microwave.  It functions perfectly in each mode albiet the microwave is mighty zesty.  The real cat's meow is being able to cook on mix power with both the gentle heat of convection to give browning, caramelization and wonderful taste with microwave power to speed the cooking process and increase the moisture content in finished meats and cakes.  I love it, use it daily, depend on it for an extra oven and love the way is saves my "bacon" by getting food on the table in record time when I am running later than my guests.  Convection is simply the baker's best friend (next to Greg and his Turquoise Frigidiare or perhaps just Greg) and does a bang up job on most meats and poultry.
Maxim
Are now understood :)
Thank you Launderess and Vacbear58
Yes your right I do have the larger version its a good oven it roasts and bakes to perfection just as long as you remember it cooks quicker than a conventional one, Now I have got used to it I am fine had a few burnt offerings to start with...lol
My microwave is also a fan oven with a halogen grill and thats handy for doing small amounts it saves electricity its mostly used for pizza and Pan au chocolate..
Austin
Nice! It looks like the middle rack slides out like a regular oven. Have a old faberware convection oven my grandmother gave to me, but it is at my mom's house. It really comes in handy for family get-togethers. I don't have much extra room in my kitchen, and my toaster oven is pretty old, so I am thinking of replacing it with a convection toaster oven. I like the Breville Smart Oven, but also feel guilty buying something new when my old toaster oven is still working.
