Its time..........
robbinsandmyers
Oct 31, 2015
858
Conn
To invest a little money into a very trustworthy machine thats been great for the 6 years I've run the snot out of it. I got my 1974 A407 from a friend for $50.00. It was working fine but I replaced the belts and H&C hoses because they were original. After 4 years the timer started acting up as soon as it would go into the rinse cycle. Found a used one online and its been fine since. Does 3-4 loads per week faithfully. Plus my landlord uses it once in a while in their tailor shop to wash the whites they iron on. Tonight while doing a load I noticed a little water leaking out the bottom and pulled the front panel and lifted the top cover to find the water injector coupling spraying all over. Its vented and the rubber hose inside has 3 pin holes. Also the hose going from it to the tub was chafing and almost worn through. I started thinking that the tub bearing is also clunking and with the front panel off I could hear the upper bearing starting to hiss on spin plus the damper pads are worn away. At first I was just going to replace the hoses then decided to go right through it since its all original still and I will never have to replace those things again. So I ordered the injector hoses and coupling, both bearings, damper pads, tub bearing and also seal. I'll do it in stages. Eventually I'm going to drill a 1/8 NPT hole in the trans and change the oil as well. I figure this machine will last many more years after this. I wasnt crazy about spending that cash on the clutch tool but I need it. About $240.00 total for everything.
Even if you have to make repairs and adjustments every now and again it’s still better than spending over $600 to $700 on something that will only 5 to 6 years. My Maytag A606 along with the matching DG306 were sitting in storage for at least 20 years, and the only thing that needs to looked into is the damper pats but otherwise seems to works just fine. My 1973 Maytag A606 shows no signs of leaking oil, and is very clean inside
Rebuilding a Maytag DC Washer From The 70s
Hi John, you should tear it apart first to see what you may need, The two main reasons our customers give up on this vintage MT is rusted and sizing top agitator shafts and damper pads that wore away or came loose and left the aluminum damper dome scored.
If the transmission shaft is in bad condition you need another transmission, likewise with the damper dome. We find the most economical way to fix these older MT DC washer is to get a low mileage much newer machine and use the parts, in this area I see MT TL stacks every week on the recycle pile that look like new inside. These usually come out of small condos where there was little use and people are replacing because the dryer has a problem and they know it is old.
What is a clutch tool ? MT does not even have a clutch as such.
"Maytag85:Even if you have to make repairs and adjustments every now and again it’s still better than spending over $600 to $700 on something that will only 5 to 6 years. My Maytag A606 along with the matching DG306 were sitting in storage for at least 20 years, and the only thing that needs to looked into is the damper pats but otherwise seems to works just fine. My 1973 Maytag A606 shows no signs of leaking oil, and is very clean inside"
I agree, they dont make them like this anymore and even though its got a lot of time on it, its been very reliable over 6 years and lots of use. If I could find a clean spin basket for it even better. It should run like new once all is said and done.
"Combo52:
John L."
My main problem is I need the washer to do clothes every 3-4 days so cant tie it up long, thats why I will do all these repairs in stages. The water leak issue one day, then the tub bearing and seal another day. Then drill and tap the trans and drain and change the oil another day. I have the 806 pair in my apartment but that is a huge project to swap the washer out while I repair this one. Plus no room in the basement to have two washers at once. I'll pull the agitator tonite and snap a pic of the shaft for your inspection and advice. Sorry I meant brake tool, thats the gear head in me thinking clutches.
"Chetlaham:Its so sad and tragic that people are unaware of the holy grail they had. One of the greatest pieces of ingenuity and history the human race has ever created."
I say that every time I see someone junk a Volvo 240 or old Mercedes diesel still in good shape.
I actually had to do more work to the Maytag DG306 than I had to do to the A606. My Maytag DG306 was originally a KDG606/DG606, but the electronic dry control was being a Royal pain so I just put a 306 timer in it to make it simpler. Thankfully I was lucky and found all the seals I needed for my Maytag DG306 since the felt seals were compromised, and I didn’t want to use it with the old crispy seals. Only things that had rust on my Maytag DG306 was the rear panel, drum pulley and rear part of the blower/fan housing and that’s all the rust it had on it. They came from Los Angeles which is more damp since I live 65 miles inland, and the damp environment combined with the pilot light will cause rust inside especially if it’s in a damp basement. Wont really have to worry about rust on my gas HOH since it’s kept in a dry laundry room and I usually turn the pilot off after I am done drying clothes in it.
Maytag brake Removal Tool
Hi John, I have said it before, I find the MT BRT hard to use often ineffective and even dangerous as it often slips off and you wack your hand etc.
Especially if you are used to working on cars it is a piece of cake to remove the brake assembly from a DC MT washer.
Remove the drive pulley, then remove the locking bolt and clip, Then get a large sturdy Vice-Grip and clamp it on the edge of the BA next to one of the screws and take a hammer and give the VG about two whacks and finish unscrewing by hand.
If you have dissembled cars you will appreciate how easily this comes apart.
combo52.....
As promised heres a pic of the agitator shaft. I started doing a load tonite and remembered I was supposed to take a pic LOL. When my parts come in I'll sand it and paint it with some zinc chromate primer. The top seal will also get replaced as it leaks oil some times and leave a spot or two on a load of whites. Also a little play in the bushing.
transmission......
I have a complete trans for a 1964 A500. Will the case work? I have that plus console electrics and a good bakelite agitator for trade if anyone has a good trans I could swap in plus spin basket
As an additional bonus, swapping the top half of the transmission as an assembly also conveniently saves you from one of the most difficult parts of a transmission rebuild - removal (and reinstallation) of the groov-pin and pinion gear from the agitator shaft.
I think Friday I will split that 500A trans and clean and prep it if the top bushing is still tight. I know my friend said it would spot the clothes once in a while. If the seal is bad but bushing is OK is that normal? If I have to split the gear case I may as well buy the nylon gear and the synthetic oil someone advised here a while back.
I cleaned the top half of the 1964 500A trans today but didnt waste time taking it apart in case I was advised not to bother. The o ring was split so I removed it. The shaft where the seal rides has wear and pitting. I was thinking of coating it with a good zinc chromate primer to fill in those voids. The shaft has no play in the bushing at all so its a shame about the pitting. Will this be a problem with a new seal? Also, what weight Redline synthetic oil should I pick up for the trans and how much? Thanks.
Please school me, Is it common for agitator machines to have the shaft and seal terminate below the water level? Seems like a the better design is like mu old Whirlpool that has the shaft seal at the top of the tub housing , way above the water level... just asking
Joe B
