It's Timeline time!!
turquoisedude
Aug 8, 2007
10,562
Norge Timeline, that is!!
So, I managed to get back from the UK visit in one piece and still slightly sane but we're in the middle of bathroom renovations down in Ogden and it seems like winter decided to start  in earnest (we had a good foot of snow and the temperature dropped to a record low today).  But I knew there were two 'new' goodies waiting for me in the garage.  And a little cold weather was NOT going to stop me from playing with at least one of the new toys.
I picked the Norge, thinking it may have been in need of less TLC than the ABC.  As usual, I was wrong... LOL
I tried to power up the machine and nothing seemed to happen until I remembered that pop-up out of balance switch, so I pressed it....
Well, still nothing happened... The motor buzzed and no motion was observed in the machine.  The Timeline had been set to the 'Wash' part of the cycle.  I pulled the plug and tried to move the control to 'Spin'.  It wouldn't budge.   Pulling the control out seemed to cut the power to the motor and pushing it back in again sent power but that was it.
So, I figured this was a good place to start!
Yes, in my usual 'Never Think Things Through' approach, I took the Timeline cycle control unit off and took it apart.  Of course it was only AFTER I had removed all the wiring that I thought about looking for a wiring diagram...  Fortunately I have one still on the machine tub and I obtained the 1957 Norge washer manual from the manuals library.
It's a fascinating unit - even I could figure out what it was supposed to do!   But, note that evidence of high heat melting on the back cover.  And note the evidence of arcing on the contact 'fingers'.... Methinks there has been a short somewhere and perhaps this was what caused the machine to be taken out of service.
But I was still troubled by the lack of movement of the selector knob...  After reading the doctrine, I figured out there was something wrong with this bar that moved an engagement gear on or off of the screw that the timer rides during operation.   My apologies for the poor picture quality - this was the best close-up I could get...
So, after adding some fresh lithium grease, I put the unit back together again...
Miraculously, it worked!  I could now pull the control lever out and move the Timeline to wherever I wanted to on the control.
And here's another clue as to the age of the Norge (I know....awful picture)....
So, if the timer was made December 19th, 1955, I'm going to hazard a guess this Norge of mine is a 1956 model.
Now, if the weather warms up next weekend, I'm going to have to try the motor again but after removing the drive belts.   I'm guessing I may have a 'stuck' pump.  Let's just hope it's not the transmission!
Welcome Back.
Paul, Our neighbor on the Cape had a TimeLine. I don't know if you know this, but on the one I saw when you pulled out the Control, it would start filling before you set the "Time on the Line".
When are you coming down ??? Hmmmmmm ?????? John's not back yet, but you could always come down here for a overnight. Or we could just break a window at his house. LOL Then we could eat and drink everything in site like we always do !!!
great post
And pictures. I look forward to following up with this thread to see your progress!
Keep up the good work!
Keeping my fingers crossed for you...
;o)
Update on the Timeline
So, I spent the past the week down in Ogden to help move the bathroom renovation project forward... It's probably going to be a few more weeks (or months... sigh) until that gets done and after a week without a fully functional bathroom, I felt a touch of the plague coming on so I bugged out to the more 'urban' setting of St-Lib this evening...
But I had enough spare time to do some more tinkering with the Norge and the news is most encouraging!
Now, when I first tested the machine,  all I could make the motor do was buzz.  I knew something was stuck or seized, so I figured I'd try removing the belt.
Eesh!  I could use this to rack up billiard balls....
I was able to access the main components and try to give them a spin manually...
The transmission pulley turned smoothly.  The motor pulley turned smoothly.   The pump.... er.....
Well, as I suspected, it was frozen up but good.   Now, this is a first - I actually diagnosed a vintage washer issue correctly on the first go round!  LOL
I figured I had nothing to lose by removing it and inspecting it.
I knocked out the pump shaft... This is where I am not so sure I was doing the right thing - that washer or gasket and sleeve looked nothing like the pump bearing/bushing/sleeve components that I was able to reference in the Norge washer doctrine.   EEP!
I wasn't sure if there had been a leak that had caused the pump shaft to gum up or not.  I again figured I had nothing to lose by testing the pump casing with some water in it.
Well, I was thrilled to observe that it 'held vater' and there were no apparent leaks from the pump shaft!  Looks like I might be ready for a test soon...
I do still need to get a new belt (one that is actually flexible would help, I'm sure...).
Almost forgot, I did try reconnecting the timer that I tinkered with.   This time, with no stuck belt or pump, the motor ran smoothly and the Timeline advanced smoothly through fill, wash, spin, rinse, and dry phases of the cycle.  I heard the fill solenoids buzzing and no fuses (or neighbourhood transformers) blew so I think I'm in good shape here...
I'll have to pull the fill valve and give it a good cleaning still, but I'm getting closer!
