Denim = 149°F
Regular = 149°F
Perm Press = 140°F
Delicate = 127°F
Cool-down to 95°F on auto-dry cycles. Variable 5 to 10 mins on timed (depending on selected/elapsed dry time I assume).
Dual heating elements, 3.6KW and 1.4KW.
Elements are used as follows and don't activate until the drum gets up to full speed. The larger element is powered off about 30 seconds before the motor pauses for reversing to prevent excess heat from entering the drum.
<li>Denim and Regular -- both in forward direction, 1.4KW during reverse.</li><li>Perm Press and Delicate -- 3.6KW in forward direction, 1.4KW during reverse.</li>
Gas has a 30-second burner ignition delay, then runs the burner for 3.5 mins maximum duty cycle during forward tumble on Denim & Regular, 2.5 mins duty cycle on Perm Press & Delicate. NO GAS HEAT during reverse tumble on any cycle.
A complex algorithm is involved in dryness sensing, which includes consideration for clothes brushing against the sensor bars more often with large loads and less often for small loads.
Regular = 149°F
Perm Press = 140°F
Delicate = 127°F
