Jet Cone Removal for 1968 Rollermatic
Yeah, you gonna need some POR15 all right, but once you give it a good coating or two, you won't have to worry about the rust anymore----unless the tub becomes badly out of balance and scrapes the side really hard---again.
By the way, take some liquid gasket and seal over that balance ring plug real good while you can get to it.
This machine is going to look great when you get through with it, and ya'll are gonna love using it.
Steve-----
Take a fine paint brush and paint the Sno-bowl all over real lightly so it won't run and try to even everything up.
Just rinse it all off at the same time real fast with a sponge so as to be sure none of it is left adhering to the tub walls,etc.
Glad you made some progress Steve, now the next one you tackle wont be so bad! It will go back together a lot easier than it came apart.......Im sure you will have it up and running in no time!
steve (gyrafoam)
Hey Steve when you said above "By the way, take some liquid gasket and seal over that balance ring plug real good while you can get to it." ..... what is the balance ring plug and "how much" liquid gasket to use ? a light coating ?
