jumper across terminals to test...
rickterry
Sep 23, 2016
6
Ohio
Hello,
This is a photo of the Hot Wire Relay in my oven. As you can see in the picture, there are four terminals. I am getting 240v across the top two terminals. The bottom terminal on the left, (terminal 1) is jumpered from the top(terminal 4) and has 120v on it. The bottom right(terminal 2) if the wire is disconnected, has zero volts. Can I jumper from top right terminal(term.3) to bottom right terminal to see if the oven works?
Thanks.
