mstone
Hello all! I just bought and brought home my first wringer washwr! A maytag E2LP, with a red agitator, for only $50! It agitates fine thank goodness, but the wringer wont turn at all and the bottom roller comes out of its holder, and the pump will not work.
The lever work and correctly moves the pump wheel into place, but the pump wheel will not turn. It has a flat spot on it from being rubbed, and when I take the pump off to turn it manually, the wheel unscrews and screws in, and when it screws in, it stops. When unscrewed to be loser, water leaks from the center of the pump. What am I missing with this thing? Why would the wheel to turn the pump unscrew and screw in? I am confused by that. As for the wringer, the ringer post turns when i pop off the wringer, but no mechanisms inside the wringer turn. I was able to manually turn it by taking off the top of the wringer and fitting the roller into its holder and turning it with a lot of force, but it barely moved. Also, what is the best/easiest way to clean the tub, the agitator, and to get the rust off the metal below the agitator? Thank you! All help is greatly appriciated!
