Hello all,
After months of searching, I finally dragged home an early gray Maytag wringer washer. I believe it's a model 90 from the late '20s, but if someone could confirm the model number and manufacture date, I'd appreciate it! The serial number on the edge is 428139N.
This came from an estate where the owner passed away over ten years ago at age 98, but the house had not been cleaned out until now. The family *thought* this washer was purchased new around 1928 and it was in regular use until about 2001. Then, it sat in the basement of that house until I dragged it out today. Had I not saved this, it would have likely gone to a scrapper.
The top soft rubber roller is dry rotted and mice had a field day with the power cord, but other than that, it seems to be in decent shape. The interior of the tub doesn't have any serious corrosion, pitting, or other condition issues and the agitator slides on and off the shaft smoothly. The lint filter is still present underneath the agitator. The motor was made by General Electric and appears to be the original. I haven't taken the cover off the belt, but I am assuming it will need to be replaced after sitting for 13+ years.
I've worked on many vintage electrical and mechanical appliances over the years, but this will be the first time I've tackled a wringer washer. My wife is looking forward to using this. Can anyone tell me what normally needs to be done to one of these to get it back in running order? I figure I will have to clean and lubricate the motor and possibly clean and re-pack the gear boxes at a minimum. Are there any gaskets that need to be replaced?
Any advice or comments are appreciated! A picture of the Maytag is below, along with a link to my album with more pictures.
Thanks,
Tom
http://automaticwasher.org/cgi-bin/00ShowCollectionGETD.cgi?dir=/COLLECTIONS/ZENITH82/
Thanks,
Tom
