Just when you thought you’ve seen it all on marketplace
maytaga806
Nov 20, 2012
692
Howell, Michigan
Why are people so utterly clueless. This has got to be the most ridiculous thing I’ve ever seen before on here. The photo speaks for itself. Can’t imagine how long it was used like this and it’s probably why they are selling it cause nothing on the top rack is getting washed and they wanna get it sold for that cold hard cash so they don’t mention that part.
Ha yep.  I remember opening the dishwasher at a friend's house in England in the 90s and the upper rack spray arm had been installed upside down (holes pointing down!).  I think the water was just pouring out of the feed tube and nothing was going through the spray arm.  So I corrected that in about 2 minutes!  The upper rack was fairly full of dirty dishes at the time, so they must have still been getting washed to some extent considering they had been using it like that.  But I wonder how well that Point Voyager would wash the upper rack with no feed to the upper arm.
The classic ones I find are metal latches drilled and screwed into the dryer door/cabinet instead of buying a $5 strike that takes seconds to replace.
This is a WP PowerClean dishwasher. Maybe in my part of the country, but just about everyone I know who had one of these, the water valve eventually got restricted to debris or calcium buildup wich yielded very insufficient water fills and horrible cleaning results. These dishwashers were extremely sensitive if they didn't receive the full fill as they weerre designed to.
I can tell you that from experience with 30 years with my portable Whirlpool quiet Wash DP8700XT.
I don't know what it was with the low energy wash, but it would not sufficiently fill when set to that cycle.
I often had to go around with the dial again.... Real weird.
Other than that I never had a dishwasher prior to that power clean and the two I've had since really aren't in the same League.
The GE portable I have now is quite good at cleaning but drying sucks.
@appnut: This looks like a Point Voyager. You can tell be the smaller detergent cup size, fully rounded heating element, and shallow float.
@agiflow: Were you advancing the timer manually to "off" as to avoid the heated dry cycle? Whirlpool dishwashers use an incremental based timer. Meaning if the timer is manually advanced without finishing an increment, it will continue advancing from where it was left off (time wise) even if the timer is manually moved to a new position. In other words if a 2 minutes per increment timer is manually rotated after 1 minute 45 seconds while sitting in an preexisting position, the timer will only hold the new position it was manually advanced into for 15 seconds.
It is for this reason I have always believed that Whirlpool should have used a "lead in increment" on their timers to off-set people manually advancing the timer forward at the end of the cycle. The only down side is you'd then have customers complaining that their dishwasher isn't doing anything for upwards of 2 minutes.
A down side to moving the timer dial around is that it opens the detergent cup and releases the rinse aid prematurely. Both creating several problems on their own. I prefer machines where the detergent cup and rinse aid are triggered electrical either via a solenoid, bimetal or wax motor. Manual cam triggers don't let the consumer make an honest mistake.
@[COLOR=#000000; font: 12pt arial bold, sans-serif]Foraloysius: [/COLOR]I shouldn't have to mention this (again) however God/Nature makes everyone different. Jerome is visually impaired. He genuinely can not make out the interior design of this dishwasher. And considering that a visually accustomed member mistakened a Point Voyager for a Power Clean I certainly don't expect Jerome to get it right on the first try. There is also the fact I can not mentally process half the world I perceive, so I guess the adage "nobody is perfect"  holds true.
Well Chat, the point is that if someone mistakes a Point Voyager for a Power Clean but doesn’t know it’s a Whirlpool they must have learned little in all those hours they are spending on this site. Probably more interested in ranting than learning something. That has nothing to do with being visually impaired.
Difference being Bob can see the inside of the machine in detail, Jerome sees varying shades of gray scale. Thus Jerome can not apply what he has learned via direct observation. Those shades of gray will all look the same be it a GE, Whirlpool, Maytag Jet Clean or Hobart Kitchen-Aid.
US built dishwashers that underfill
Pretty much all dishwashers had problems with underfilling as they age the valve diaphragm wears out in the valve, all American dishwashers use the same valves so it was no more common on GE than whirlpool and Maytag, etc..
This problem is never caused by mineral buildup, it’s caused by the rubber diaphragm wearing out taking the valve apart and cleaning it will not solve the problem permanently sometimes they’ll work a little better if you take the valve apart and play with it the only real cure to replace it with a new valve or a known good valve.
The good news is this problem has largely been solved, new whirlpool dishwashers now since the water load on the motor and can add more water as needed, so we’re not seeing nearly as much of this problem as we used to, just one more way that modern dishwashers with computers are actually far better than ones with the old mechanical timers.
John L
Water fill valves
Regarding water fill valves there are no diaphragms in the RobertShaw/Invensys appliance valves.
They use a rigid plunger that can be clogged with mineral buildup. Same for their inlet screens.
Irrigation valves like I have in my yard, use pilot channel diaphragm valves. Those are too big to fit into appliances.
First pic is an appliance valve.
Second is an irrigation style pilot valve.
