Just when you thought you’ve seen it all on marketplace
Early whirlpool built, tall tub dishwashers
Or PV for short, as many of you know, I had one of the first KitchenAid tall tub dishwashers. It was a little bit disappointing, especially in the corners of the upper rack, it was still far better than any dishwasher I’d ever use that had a pop-up tower in the middle of the lower rack that didn’t even begin to clean in the corners.
Whirlpool made several slight design improvements, which made them work better as other experts on the site have noted.
The only main thing I would’ve changed on the point Voyager machine. It should’ve had a removable trap that was easier to get to catch large and hard objects That protected the grinder.
It did have an effective trap, but you had to remove screws and do some disassembly to get to it. It tended to get blocked with in organic objects. It’s a plastic large fruit pits, broken glass, etc. to protect the grinder.
I have NEVER seen a clogged grinder on a point Voyager machine it absolutely does not happen. I’m tired of people saying you have to take the machine all apart and clean the grinder screen. Yes this happens but it’s only when the grinder mechanism is broken. Otherwise, it is never necessary in the life of the machine.
There are videos all over the Internet of idiots saying you have to take this machine apart, showing pictures of clogged grinder screens, and they’re not addressing the real problem. The grinder or the drive teeth are damaged. It is never necessary to clean the grinder, I have never had to do a service call on a dishwasher to clean the grinder screen. If it’s clogged, there’s something that needs to be replaced.
John
About the point voyager chopper, Our chopper was working the entire duration we owned it but when we got it used I think the chopper wasn’t working because it looked like it wasn’t fully attached anymore when I opened it up to unclog the sump so yeah. The metal screen behind it was very plugged with all kinds of little food garbage so that’s exactly why, the chopper came off somehow rather the previous owner tried to fix it and gave up or something. After I put it back together I could hear it working and after that it never got clogged again. I loved that machine a lot. Never pulled out a dirty dish from the top rack ours worked excellent and I believe it was one of the latest revisions whirlpool did for that series.
Look at this though, I have never seen a point voyager with a SLIDING DISPENSER? I thought whirlpool started making these in like 2018? It couldn’t have been replaced with this as the opening for the dispenser would have been too long to fit this in for the normal rectangular dispensers these Maytags always had. And also I’ve never seen a black top control panel on one of these Maytag top controls they were always silver if the exterior was stainless.
