K B I S LAS VEGAS
laundromat
Feb 9, 2010
4,209
Hilo, Hawaii
I Had a great time and saw so many new and improved products from all around the world.Included amung them were GE's new line of products including some new induction cooktops they're introducing this summer.Sears willalso have them available.The new GE front loading/stackable washer is so like the Duet that the only difference other than the style is perferated wash arms inside.the dispenser tray,the rubber boot,the door seal and tub are all similar.The LG products were breathtaking!they unvailed an entire line of electric ranges with thermal/convection ovens,dishwashers that used less than 5 gallons of water per load and will hold as many dishes as a service for sixteen,a new 3.85 cu.ft.capacity washer and 7.5 cu ft matching dryer that can be connected to your laptop computer or PC for easy acces control.There will be a new set available this summer with a washer that has a 4.0 cu ft.capacity and a matching 8 cu ft.capacity dryer.KitchenAid unvailed their new professional front loading Ensemble set in real stainless steel exteriors!!!The washer is 3.8 cu ft and the dryer is 7.5.The washer amnd dryer both have stainless steel drums and the dryer has a lint filter made of steel screening that is horizontal and located just beneath the door opening.It slides forward and is real easy to clean and replace.So much more to talk about.Please email me if you have any questions.I took pictures and will try to send them via cd to the sight.
