KA late model DW owners; can you check water level
Repair guy said it should be fine, just not as quiet as it should be.. but I can just see it screwing up right after the element gets repaired.. in which case should that happen it'll be sitting on the curb.
Pete check your warranty
Refer to your use and care guide. If there is a motor problem, it is covered for 5 years. The heater is too.
Pete, if it was determined that it was made in 2003, the part(s) are covered and the warranty is transferable. If you look at the web you'll find the warranty detail there too. KitchenAid.com
